Is My Shower Drain Normal? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2012, 04:03 PM   #1
Rewards Points: 1,062
Is my shower drain normal?
People,
House built in mid 80's, shower stall, drain is only about 2 1/2 " wide. Strange thing is the inside of the drain appears concrete like. I would have expected pvc material, not concrete.
Thing is, with drain being sluggish, I thought to snake it. have a cheapo HD snake (plastic), and whenever I put the plastic snake down there, the rough concrete drain walls kinda rough up my snake (not that that is my main concern, just that I think this is unusual, and hindering my snaking).
Is this normal? Also, could I rent from HD a real snaker? Do they come with different diameter attachments?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 01-18-2012, 04:12 PM   #2
DIY staff
Rewards Points: 7,174
A picture would help----Rental places have all sizes of snakes for rent---that's a 2" drain (should be anyway) so a small unit will do the job----
I'm curious about that drain----that new of a house would typically have PVC---
Is this going into a concrete slab or a framed floor??
noquacks (01-18-2012)
Old 01-18-2012, 04:16 PM   #3
Thaks, Mike! Yeah, I did take 3 pictures- all came out out of focus....dang. yes, its a slab base/floor. Maybe I could try chipping away at the walls some? hate to have a chunk of concrete fall down the drain, causing MORE trouble, eh?
Old 01-18-2012, 04:22 PM   #4
you know, Mike, it just hit me- that "concrete" is probably just calciumated (a word?) crud over 25+ yrs, from al the hard water right? I bet some strong muriatic acid (50/50) would dislodge that real good, eh? heck, that alone may also take care of the junk farther down......
Old 01-18-2012, 04:27 PM   #5
DIY staff
Do not dump chemicals in the drain----if you end up using a snake---you will now be working in an acid pit--
Besides--the chemicals seldom work any way---get a small power snake---should have a drill like handle and a small drum---Mike---
Old 01-18-2012, 04:31 PM   #6
good point- but dont worry (although, I appreciate your concern/warning), I am very experienced in acid- I would firstly have flushed the hydrochloric all down with slow trickle of water for 10-15 min before any work, maybe with some sod bicarb too to neutralize. Still, snake first is a smart plan.
I'll let you know what happens (may be the weekend).
Thanks, Mike!
The Following User Says Thank You to noquacks For This Useful Post:
oh'mike (01-18-2012)
Old 01-18-2012, 05:07 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 994
The issue with chemicals is apart from the safety , It can really do a number on your plumbing, yes even plastic, you can break that scum you see around the drain then pull it back with a wet vac, then cable the line while running water through the line.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is online now   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Old 01-18-2012, 05:47 PM   #8
OK, more good tips on snaking.....I didnt know about running water while doing it.
New shower drain installed, but gasket not sealing dryvlyne Plumbing 5 10-23-2011 09:29 PM
No drain trap in a 7-year old home - is this normal? curls00 Plumbing 2 12-05-2009 12:40 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
New tiled shower won't drain; mortar in drain. catitudes Plumbing 5 03-29-2009 01:08 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
