My Plan: PEX Piping Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2011, 08:22 AM   #1
Rewards Points: 198
my plan: PEX piping question
i'm installing a new bathroom in the basement and will be roughing in water lines for a toilet and shower. Since it's the basement, finding both a hot/cold water feed was not a problem. However i'm a bit weary about soldering but found a fantastic alternative called PEX. couple of quick questions here tho
1. is it bad if i split my copper lines and install a T connection that connects to a PEX pipe?
2. how do i secure the PEX piping to the wall? same bracket as the ones the brackets for copper lines? does it need to be secured at all??
3. can i split (T) a PEX line?
4. for a toilet water line and showers, isn't it required by code to have shut off values? if so, it seems like having copper line maybe a little more rigid??
vote4Pedro is offline   Reply With Quote
Old 05-25-2011, 11:27 AM   #2
PEX clip gun is used to secure PEX in radiant heating installation. Perhaps, it can also work for plumbing purposes as well.
genie01 is offline   Reply With Quote
Old 05-25-2011, 08:57 PM   #3
Rewards Points: 198
bought some crimping tools today.
the plan is to run 3/4 pipe from the main line for both hot/cold to bathroom where they'll split to the following:
1. main line will be a 3/4 copper split T with another adapter attacked for pex
2. 1/2 split to cold for toilet
3. 1/2 split cold/hot for wet bar on the other side of bathroom
4. 1/2 split cold/hot for small 32x34 shower.
sounds about right??
question as to do water feeds have to come from the floor or can it be drawn in from the ceiling?? this is a pretty low basement.
edit.. there are several different pex pipes out there. which brand should i get? i've read that some are terrible.
Old 05-25-2011, 09:33 PM   #4
It's fine.
Talon clamps. Yes they need to be secured, ~ 36" horizontally according to my code.
Yes.
Yes a shut-off valve is required for toilet, and the new shower valves come with built in stops. For toilets, sinks, etc..., use a copper pex stub out.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
vote4Pedro (05-26-2011)
Old 05-25-2011, 09:40 PM   #5
1 through 4 are fine.
Either way is fine.
I can't speak to what brand names are available to you, but I go with what my local plumbing supply houses give me. Make sure whatever you decide to use is rated for potable water and has some type of certification (UL, CSA, ...).
Two part question - novice alert mcgolden Building & Construction 5 10-11-2010 11:51 PM
To silt fence or not to silt fence that is the question tomseeley Landscaping & Lawn Care 2 08-30-2010 07:13 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
Would like a BUDGET landscaping plan. Bacardi 151 Landscaping & Lawn Care 7 04-05-2008 10:06 PM
