My Pedestal Is 1 Inch Taller Than My Current Basin On D Wall. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-01-2011, 12:06 AM   #1
My pedestal is 1 inch taller than my current basin on d wall.
What should i do that my pedestal is taller than my basin. When i fit in the pedestal, the drain pipe on the wall leak. The drain pipe seems require to b longer...
JolenetanZ is offline   Reply With Quote
Old 11-01-2011, 05:51 AM   #2
DIY staff
Rewards Points: 7,174
A picture would help---
Every time a new sink is installed--the P-trap and drain piping should be replaced--also the waterlines.
four inch plastic drain pipe through concrete foundation wall dan patterson Plumbing 11 01-25-2011 06:23 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
