My Outlet To Field Is Without D Box Or Manifold. What Is With The "left, Right, Left, Etc. Dispersing Tiles? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2011, 09:58 PM   #1
My outlet to field is without d box or manifold. What is with the "left, right, left, etc. dispersing tiles?
john merz is offline   Reply With Quote
Old 02-18-2011, 10:56 PM   #2
Rewards Points: 1,512
A leach field with a distribution box will allow a larger flow rate compared with a single back and forth pipe with no d-box. Peformance of a single back and forth pipe is further impaired if the field is sloped overall from one end to the other because there are uphills in the pipe path. This could pose a problem when large flows occur such as from using several plumbing fixtures and/or the washing machine at the same time.
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Ceramic tile on slab - install over adhesive left from vinyl tiles? softwareguy Flooring 1 08-23-2008 10:48 PM
