My Laundry Basin Takes 2 Hours To Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2011, 09:31 AM   #1
my laundry basin takes 2 hours to drain
The washer drains directly into the basins drain pipe. not into the basin tub, so while the washer is emptying its full volume of water it fills the basin tub coming up through the basins drain. the water collected in the basin tub then takes around two hours to fully drain. This makes it impossible to start another load of laundry until it drains completely. There is not a particle catch from the washer to the drain. What should I do. Is my entire drain setup wrong. I would like suggestions for a proper setup.
camhendo is offline   Reply With Quote
Old 01-29-2011, 10:17 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,078
Ayuh,... By cleaning out the Drain,..??
Pull the trap, 'n Clean it...
If that ain't the problem, snake out the rest of the lines...
Old 01-29-2011, 12:37 PM   #3
Rewards Points: 530
I agree with Bondo. If it still drains slow, check the venting.
Very slow drain no drain blues Plumbing 16 04-03-2012 05:39 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
