My Kitchen Faucet Rusted Loose - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2013, 08:26 PM   #1
Rewards Points: 372
My kitchen faucet rusted loose
My original flat-washer (or flat bar?) brackets rusted off my delta washerless kitchen faucet. I'd like to get a couple of these bell shaped brackets instead:
I see it is labeled "bracket". What kind of bracket, and where can I get them? The "bells" would be big enough to go over the top of the old, rusted nut and I could spin new nuts on to tighten the faucet back into the sink.
The original brackets have simply crumbled away. Am I correct in not wanting to disturb the original nuts? I'd hate to damage the mount rods by trying to loosen rusted on nuts if I don't have to.
imautoparts is offline   Reply With Quote
Old 01-28-2013, 08:39 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
If you're going down the "replace parts" road you're best off to call the factory rep.
Me- I'd get a new faucet or fabricate the parts you need
The Following User Says Thank You to TheEplumber For This Useful Post:
joecaption (01-28-2013)
Old 01-28-2013, 08:46 PM   #3
Rewards Points: 13,300
If it's that old it's time to go.
Old 01-28-2013, 09:10 PM   #4
Rewards Points: 582
the bracket rusted off because base of faucet is leaking ..must be a small leak...but if you dont repair the leak it will only get bigger....i say replace faucet also..ben sr
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 09:29 AM
Kitchen faucet: did I mess it up? mikew Plumbing 3 06-28-2010 03:35 AM
Replacing a kitchen faucet Anna123 Plumbing 3 06-09-2010 06:48 PM
taste of chlorine in water from newly installed kitchen faucet ilyaz Plumbing 4 04-20-2010 04:14 PM
Can I install a kitchen faucet on Utility sink/tub?? TDRohn Plumbing 4 09-17-2008 01:13 PM
