-   -   My kitchen faucet rusted loose (http://www.diychatroom.com/f7/my-kitchen-faucet-rusted-loose-170422/)
imautoparts 01-28-2013 08:26 PM
My original flat-washer (or flat bar?) brackets rusted off my delta washerless kitchen faucet. I'd like to get a couple of these bell shaped brackets instead:
http://images.meredith.com/diy/image...SCP_085_06.jpg
I see it is labeled "bracket". What kind of bracket, and where can I get them? The "bells" would be big enough to go over the top of the old, rusted nut and I could spin new nuts on to tighten the faucet back into the sink.
The original brackets have simply crumbled away. Am I correct in not wanting to disturb the original nuts? I'd hate to damage the mount rods by trying to loosen rusted on nuts if I don't have to.
TheEplumber 01-28-2013 08:39 PM
If you're going down the "replace parts" road you're best off to call the factory rep.
Me- I'd get a new faucet or fabricate the parts you need
joecaption 01-28-2013 08:46 PM
If it's that old it's time to go.
ben's plumbing 01-28-2013 09:10 PM
the bracket rusted off because base of faucet is leaking ..must be a small leak...but if you dont repair the leak it will only get bigger....i say replace faucet also..ben sr
