-   -   Is my Hot Water tank Going (http://www.diychatroom.com/f7/my-hot-water-tank-going-51975/)
K.M.G 08-30-2009 02:51 PM
Hi
I think the Hot Water tank is from 1989 when the home was built
I only seem to have enough Hot water for maybe 10 mins and then even with the cold water turned off its lukewarm now.
It started after some idiot from the Gas Company came to the home
Now I had to have the furnace we lit and at the same time we had a leaky faucet and had to turn the water off to the house because they didn't have shut off valves under the sink.
Anyways the guy took lt upon himself to turn the water on because the Hot Water tank wasn't tuning on when he re-lit the furnace(Don't ask me why)
Since then we only have hot water for maybe 10mins ,I could have a shower for as long as needed before.
I don't know what to look for at the Water Heater,There is a Noob at the front and have turned it but nothing happens.
Any help would be great:wink:
Plumber101 08-30-2009 03:03 PM
You might check the temp setting on the water heater. Seems very odd that it starting acting up all at once.
K.M.G 08-30-2009 03:11 PM
What should it be set at
Also it's behind a panel right
Could a valve be stuck
I know since we lived here we never empty-ed the tank
Plumber101 08-30-2009 03:16 PM
Temp should be set at 120 deg
Depending of the valve it could be in deg or letters. If it is letters use setting "B"
K.M.G 08-30-2009 04:10 PM
Looks like mine has a Dial
It was set at Warm so I turned it up and it started up
Should I set it to hot
http://i2.photobucket.com/albums/y12/1cavy/P8280672.jpg
http://i2.photobucket.com/albums/y12/1cavy/P8280674.jpg
http://i2.photobucket.com/albums/y12/1cavy/P8280678.jpg
http://i2.photobucket.com/albums/y12/1cavy/P8280679.jpg
spark plug 08-30-2009 04:15 PM
Issue of hot water tank not putting out enough!
Originally Posted by K.M.G (Post 321381)
Hi
From my limited (but expensive) experience with hot water tanks. I can tell you that they don't have a life expectancy of more than Ten years. Anything beyond that, they're on borrowed time. As a matter of fact, the (pro-rated) Warranty doesn't run more than Ten years. (Now more than ever):yes::no::drink:Don't Drink and Drive!
Plumber101 08-30-2009 04:21 PM
THe first four numbers in the serial number are 1287 which tels me Dec of 1987 is when this was made.
22 years.
I'd replace it
yuri 08-30-2009 04:58 PM
It is on borrowed time, you may want to replace it before it bursts and causes a flood/water damage to the flooring. Set it to the large mark but not HOT. HOT will overheat/stress your old tank and that may be the straw that breaks the camels back.
qbert 08-30-2009 10:50 PM
22 years it has seen its usefull life. If it is firing when you turn the knob all the way up, you could flush it. Turn off water supply, turn gas to pilot, drain half tank then turn water on blowing out some of the junk inside. then close drain let it fill. turn gas valve to on.
Yamvmax 08-31-2009 08:21 AM
WOW 22 yrs on a hot water heater!!! You better replace it before your basement/house is flooded.
AllanJ 08-31-2009 02:00 PM
Note: With any water heater -- gas, electric, old, new -- water should be gushing from an open hot water faucet before you turn the burner/electricity on or otherwise fire it up.
It is possible that the gas company guy bumped the tank and something (like the dip tube for entering cold water) broke inside. Or maybe something inside broke more or less by itself.
Normal maintenance of a water heater includes draining some water every year. Not the entire tank contents but perhaps a potful if the water runs clear to begin with. Drain more until the water runs clear if sand or rust comes out to begin with.
You should not have to turn the temperature control up all the way, and also you should not have to use the "very hot" section if the dial has that.
Yoyizit 08-31-2009 04:01 PM
Gas WH, 22 yrs, only 1 in 15 lasts that long. It has a 50-50 chance of going another 9 yrs.
K.M.G 09-01-2009 11:15 AM
I didn't know a Water Heater didn't last this long:mad:
I thought it was just a big tank with a heater
What happens when It dies,just stops working???
I don't think the 2009 Rheem Water Heaters are even built like this now
Maybe I can get money back showing I have a water heater can last this long,like Cars that can go 100,000,00 miles
I can't wait for the Furnace to go ,Hell we don't even have return ducts,Let a Idiot build your house:clap::furious:
they say 2009 Homes have problems,Buy a 80's/Early 90's home
AllanJ 09-01-2009 12:30 PM
Most water heaters "die" by springing a leak in their tanks.
Failure of other components such as dip tubes, thermostats, heating elements if electric, etc. is a separate scenario and unrelated to leaking although it is OK to assume that if more than 10 years have passed and something else fails, chances are the tank is partly rusted through in spots and leaking will happen soon.
Exception: failure (loss due to corroding away or falling off) of an anode rod is normal and will not in itself make the heater stop working instantly. The rod should be promptly replaced without assuming that something else will go wrong soon.
james schroder 09-02-2009 02:22 PM
old hot water heater
i would agree that the water heater is on borrowed time but the problem as discribed sounds like a broken dip tube that runs the cold water to the bottom of the tank allowing the incomming cold water to mix with the already hot water. it can be replaced either with a plastic replacement or with a piece or 1/2 l soft copper flared on one end and dropped in the cold inlet.
james
