Old 01-24-2013, 05:33 PM   #16
Plumber
My hose valve burst AGAIN!
Install a woodford model 19 and you will never have this problem again.
I have installed a couple hundred of them over the last few years and not one has ever burst.
http://www.woodfordmfg.com/Woodford/.../model-19.html
DidIDoThat is offline   Reply With Quote
Old 01-25-2013, 02:59 PM   #17
I installed a frost proof style silcock, and then inside I used a shut-off valve that has a bleed/drain plug. This way I'm 100% sure all the water comes out. End of season I simply turn the shut-off valve to off, open the silcock outside, and then pull the drain plug on the shut-off valve. Once all the water is out I put the plug back in, and forget about it until the spring.
Good luck
HandyFrank is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Outside water hose valve turbomangt Plumbing 1 06-03-2011 08:17 AM
running extension from outside garden hose faucet denemante Plumbing 6 05-27-2011 01:18 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
