My Hose Does Not Fit The Outdoor Faucet, See Picture Inside. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2011, 01:58 PM   #1
Rewards Points: 177
My hose does not fit the outdoor faucet, see picture inside.
I am new to owning a home.
My small lawn is drying out in this hot weather. So, I thought I wanna give it a little water. I went to Lowes and got a hose.
The following picture is exactly what my outdoor water faucet looks like. Pay attention to the little holes.
I hooked up the hose to the faucet, when I turned on the water faucet, water comes out from the little holes, but refused to go through the hose. I can't water my lawn.
It seems the holes are by design, does this mean I've got the wrong hose? What should I do? Your tips are greatly appreciated.
homenewbie is offline   Reply With Quote
Old 07-24-2011, 02:06 PM   #2
Experienced
Jackofall1's Avatar
Welcome homenewbie, to the best darn DIY'r site on the web.
The connection you have picture is a vacuum breaker / backflow preventor.
No water should come out of the small holes when you allow flow through the hose ie open the nozzle on the end of the hose, when the flow is stopped through the hose water will come out of the holes.
Also you should be able to remove the VB and attach your hose directly to the hose bid.
See attached article
http://edis.ifas.ufl.edu/ae113
Mark
Old 07-24-2011, 02:10 PM   #3
Rewards Points: 177
Mark
Thanks, but the other end of my hose is wide open, I haven't even attached the nozzle to the hose yet.
Old 07-24-2011, 02:15 PM   #4
Experienced
Jackofall1's Avatar
The connection at the house is an add on piece that should be removable.
Mark
Old 07-24-2011, 02:18 PM   #5
Rewards Points: 177
Mark
Thanks again. Removing it can be a little hard, what tool do I need?
Old 07-24-2011, 02:26 PM   #6
Experienced
Jackofall1's Avatar
Channel lock pliers, righty tighty, lefty loosey
Mark
Old 07-24-2011, 02:27 PM   #7
Rewards Points: 177
Actually, I was stupid. I just tried it, and it worked like you said.
The problem was I was holding the hose in my hand, higher than the faucet, so the water does not come out. As I laid it on the lawn, the water starts to come out from the hose. Thanks!
Learning small things every day.
Old 07-24-2011, 09:14 PM   #8
Rewards Points: 1,088
Why is there mortar all over the top portion of the valve?
handy man88 is offline   Reply With Quote
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Siding Inside Corners scott j Building & Construction 11 03-03-2010 07:30 PM
Hose holder suggestions needed diyntn Landscaping & Lawn Care 5 06-27-2009 04:12 PM
Ductless unit has dripping hose in basement tockfull HVAC 3 07-20-2007 09:17 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
