My Garbage Disposal Is Leaking - Need Help To Repair It - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2012, 02:17 PM   #1
My Garbage Disposal is leaking - need help to repair it
My garbage disposal is leaking. It's an in-sink erator brand and it is leaking in the middle of the unit. When i look at it, the water is coming out of the part that connects the bottom part (i'm assuming this is the motor) and the top part which connects to the sink. i ran both the faucet and my dishwasher to confirm the leaks is coming from this middle area.
i consider myself to be handy but don't have knowledge or skill on plumbing or garbage disposals, so i can use all the help i can get.
please let me know if you need any more information.
thanks
tdeepness is offline   Reply With Quote
Old 06-18-2012, 02:37 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by tdeepness View Post
My garbage disposal is leaking... the water is coming out of the part that connects the bottom part (i'm assuming this is the motor) and the top part which connects to the sink.
1) go to the store and buy a new disposer and some putty.
2) disconnect and remove the old disposer. Clean it.
3) look it over more carefully for where the water is leaking...
if you can isolate that further and KNOW it's limited to the outlet pipe
then sure, go ahead and try to close up that leak.
4) install (or return) the new disposer.
Old 06-18-2012, 05:17 PM   #3
DIY staff
Rewards Points: 7,174
Sounds like a fatal flaw---Plan on replacing it---that's a good brand--seriously consider buying another in-sinkerator--
Old 06-19-2012, 02:14 AM   #4
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
thanks
there is no saving the g/d go get your self a badger 5 xp 3/4 hp
wctekkk is offline   Reply With Quote
Tags
garbage disposal , plumbing
fork stuck in kitchen garbage disposal and unjammable blackcheetah Plumbing 15 01-16-2012 11:51 PM
Best Garbage Disposal ToeJoe Plumbing 1 01-16-2011 10:22 AM
New Garbage disposal draining slowly. yoeye82 Plumbing 1 12-10-2010 04:40 PM
garbage disposal /double kitchen sink redroc25 Plumbing 7 11-15-2009 06:32 PM
Garbage Disposal in the country? OffRoadAudio Plumbing 6 09-01-2009 05:19 PM
