Old 03-21-2008, 09:16 AM   #1
My garbage disposal isn't working
Recently my garbage disposal became jammed. I was able to turn the plates from the top and it seemed to loosen up. But then I discovered that I can hear the motor spin but the plates are not. I used an allen wrench to spin it from the bottom of the unit, and it seems to turn freely. But the discs are not moving. Now water is very slow to drain. What do I do know?
paulb@mononapfp.com is offline   Reply With Quote
Old 03-21-2008, 09:19 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Time for a new disposal, that one is broken beyond repair.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-21-2008, 12:16 PM   #3
I blame ProWallGuy
I think Ron has it. It sounds as if the grinding plate is sheared from the shaft that drives it.
Double A is offline   Reply With Quote
Garbage disposal leaking ArizonaNick Plumbing 3 12-26-2007 05:22 PM
Garbage Disposer not working bucksone Appliances 3 08-07-2007 06:19 PM
HELP I need to wire a switch to an outlet to hook up my garbage disposal r8drman69 Electrical 8 06-05-2007 11:18 PM
DIY Garbage Disposal replacement bigbob Plumbing 1 06-07-2006 07:05 PM
Garbage Disposal on a "Grey-Water" line? Ron Plumbing 8 02-06-2006 09:25 PM
