My Boiler Doesn't Work - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2011, 07:21 PM   #1
my boiler doesn't work
I have a utica gas boiler with taco cartridge circulator and a honeywell termostat and stop working i changed the termostat and steel doesn't work
Jose pais is offline   Reply With Quote
Old 12-04-2011, 07:39 PM   #2
Rewards Points: 582
start by checking power to boiler...120 volt...breaker, fuse...
Old 12-05-2011, 07:32 AM   #3
Rewards Points: 1,216
Once you establish you have power, shut the power off to the boiler and @ the boiler disconnect the two wires together that go to the thermostat then connect the two wires on the boiler together see if it starts, if it does the there's a problem with the thermostat if it don't there's a problem somewhere right at the boiler, go from there.
COLDIRON is offline   Reply With Quote
Oil Boiler Pressure Problem soaddrummer HVAC 5 01-17-2011 06:56 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan Plumbing 21 12-22-2010 08:01 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
Low water cutoff keeps shutting boiler off dolfish HVAC 7 12-06-2010 05:26 PM
Trying to wire Honeywell IAQ to Burnham RSM/96 oil boiler 6burgh HVAC 26 11-13-2010 09:21 PM
