My Bathroom Shower??? Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2011, 07:35 AM   #1
My bathroom shower??? Help
I have a shower that is 3 by 5 and the shower drain is in one side so I pored concrete in the shower and sloped it all towards the drain pipe. "I did not cut the pipe it sticks out like a foot.". I wrapped the whole shower in orange membrane an then tiled shower without cutting the drain pipe. Was wondering if I could just sawzal the pipe and pipe in a snap drain in? Can someone help me plz
Ryan Paska is offline   Reply With Quote
Old 11-24-2011, 07:40 AM   #2
Rewards Points: 582
would need a picture......
Old 11-24-2011, 07:43 AM   #3
I'll take one when I get home, thanks
Old 11-24-2011, 03:18 PM   #4
Handyman
Rewards Points: 512
Like Ben, I don't have a reply yet..I just want to be notified when the pic comes out.
canadaclub is offline   Reply With Quote
Old 11-24-2011, 03:22 PM   #5
Experienced
Jackofall1's Avatar
Doesn't sound like you did enough research before you started your shower project, you didn't mention preslope, membrane and then the shower concrete floor.
When done correctly (membrane laid on the preslope) the drain has weep holes which allow drainage out of the shower floor before you do damage to the understructure as tile and grout is far from water tight.
The drain would be an intregral part of the preslope and membrane.
But like other said post some pic's
Mark
Old 11-24-2011, 04:29 PM   #6
Handyman
Rewards Points: 512
He mentioned orange membrane (schleuter) which could work in his favour. Depending on the drain he has.
Old 11-24-2011, 06:17 PM   #7
I didn't use a pre slope because it is a custom shower where it wouldn't fit, I sloped concrete and now I have to put membrane on and tile on, all I need to know is if a snap drain works good
Old 11-24-2011, 06:25 PM   #8
Rewards Points: 582
hi ryan.....if you can show some pics might be able to answer your question....Ben
Old 11-24-2011, 07:30 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ryan,
Get out your hammer and chisel and start digging some concrete out around the drain pipe. What it appears you have done isn't going to work. Dig out about a 14" diameter hole around the drain pipe.
Pictures!!! You said you would post pictures.
Old 11-24-2011, 08:29 PM   #10
I didn't go home tonight sorry guys
Bathroom ceiling with vapour barrier - shower light / exhaust fan mforeman1 Drywall & Plaster 1 04-03-2011 06:19 PM
Bathroom \ Shower question. Abs777 Drywall & Plaster 14 03-09-2011 06:11 AM
Bathroom Window / shower mazzonetv Building & Construction 4 02-21-2011 03:25 PM
Bathroom remodel - lighting over shower / water line s4alex Electrical 15 10-10-2008 01:15 AM
Bathroom Shower jackco711 Flooring 4 11-14-2006 09:22 AM
