My Antique Culligan Mark 89 Has Died. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2012, 01:03 PM   #1
My antique Culligan Mark 89 has died.
Help!!
I had the local Culligan Systems Tech come out and look at my Mark 89 water conditioner. He said that the control valve timer motor had died and that replacement motors are scarce, mostly only from used control units. They want to replace the whole system $$$$, but I'd like to find a replacement motor and dis-assemble the unit and replace just the motor. Has anybody out there had such a failure? Did you find a replacement, preferrably new, motor? Where? many thanks
thompsba41 is offline   Reply With Quote
Old 12-01-2012, 03:22 PM   #2
Water Treatment
Rewards Points: 848
I do know where there is a used culligan drive motor for the main piston and brine piston.
Check Ebay for culligan motor.
In the Search bar type in Culligan Motor and that should pull up the motor.
Akpsdvan is offline   Reply With Quote
Old 12-02-2012, 02:21 PM   #3
Water Treatment
Rewards Points: 848
Have you had any luck in finding a motor to keep your Culligan unit going?
Old 12-02-2012, 04:13 PM   #4
Right motor?
Hi Akpsdvan-
Thanks for the input. No I haven't found a replacement motor yet and the one you're selling on ebay might do the job if it is the right one. Is the motor for sale for a mark 89? does the same motor run the timer and the plunger or are they separate functions with separate motors?
thanks...Bruce
Old 12-02-2012, 04:45 PM   #5
Water Treatment
Rewards Points: 848
The one on Ebay is for the Culligans 89,812 and the filter controls that they used over the years.
There was some early ones that had a plate on top and under to hold the assembly to the back plate, then they change it to a single total part , either works.
The culligan motor has 2 shafts, one on top for the brine piston and one under for the main piston.
Water Softener Problems Culligan Mark 89 Thespr Plumbing 32 04-01-2016 07:25 PM
Culligan Mark 89 - Daily Dischrage Settings rfkoch Plumbing 1 05-06-2012 11:00 PM
culligan mark 89 water softener parts whriley Plumbing 5 10-04-2011 11:09 PM
Whirlpool Mark I Just died, need help KarlJay Appliances 9 04-04-2011 11:49 PM
Culligan Mark 89, water SALTY after regen. Lehouillier Plumbing 11 04-11-2010 08:47 PM
