Originally Posted by tranders
I did follow the instructions.
Actually you did not follow the directions.
Here they are again; ... mix a 1/3 cup of nonscented bleach in a gallon or two of water, pour it into the water in the salt tank, not down through the salt, and do a manual regeneration. That will sanitize the softener and should get rid of the musty smell.
Do not mix bleach with Iron out etc..
Not too interested in drinking bleach water! And I may have put a little too much in, so couldn't take the risk and what do the extra cycles hurt?
Your assumption that you would be drinking bleach water is incorrect. And why did you NOT follow the 1/3 cup directions and use MORE!!
CHLORINE damages RESIN!!
The valve went through a backwash and then a final rinse before getting back to service; but you didn't know that, but I did but...
THINK, one you don't know what to do, two, not following directions will get you what?, three, becasue you don't know what to do, you can only assume and mostly incorrectly, if you THINK about it.
You are looking to get rid of a musty odor, why would you have to drink the "bleach water" to see if it smelled musty!! SMELL IT.
Will try some Iron Out I guess. Would still like to get the valve assembly off just to get a look at the resin (curiousity if nothing else).
Iron Out etc. won't kill bacteria or odors.
You want to check the resin, go for it, you unscrew the control valve out of the tank. Even if you assume it's too hard to do 'cuz ya might break something like you already said IIRC. Trust me unless you beat on it, you won't break anything.
When you take the valve off, beware of pulling the distributor tube up any and that later when screwing the valve back into the tank you break the bottom basket causing your gravel if any and resin to get out into your plumbing as soon as you turn the water back on and run any water in the anywhere in the house. That shouldn't sound like something you'd want t ohappen...
If you aren't going to follow directions as if the thing will blow up in your face, don't expect me to tell you what and how to do anything more. So if you want more help, follow the sanitizing directions and SMELL the water for musty after flushing the stagnant water out of the plumbing and see if it does or not. And if it does if it gets stronger as you use water.
ps. the distributor tube with your brand of control valve, can not stick up out of the tank more than 1.25".
