Old 06-13-2010, 12:51 PM   #1
Multiple shower heads considerations
I'm planning a new bathroom with a multiple-head shower. What differences in plumbing should I consider? multiple water lines or can they share a line? Should I increase from 1/2 inch to 3/4 inch supply?
mnicks is offline   Reply With Quote
Old 06-13-2010, 01:14 PM   #2
Super Moderator
Any that I have seen require 3/4 " dedicated lines.Check the manufacturers spec. sheets --they know.
You can't take a mixer that is designed for one head and expect it to produce enough flow for two.
Good luck--have fun--Mike---
mnicks (06-13-2010)
Old 06-29-2010, 01:29 PM   #3
I recently installed a Moen 275 Spa set which has a thermostatic valve (mixer), showerhead, body jets, and a handheld. However, you can buy the mixing valve separately. Each function (showerhead, body jets, and handheld) has its own shutoff valve. I don't see why this couldn't feed two showerheads instead. The supply lines to the mixing valve are 3/4". 1/2" can easily come off of the valve to each showerhead. I placed the handheld at the opposite end of the shower (4'x6') for the little lady to use so I wouldn't have to get out from under the big showerhead and bodyjets :-). I ran one 1/2" line under the floor to the handheld from the 3/4 output of the mixer.
Dave
Spastic is offline   Reply With Quote
Tags
plumbing shower
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
multiple shower heads mbrewmeister Plumbing 1 05-29-2009 07:04 AM
installing multiple shower heads jimmy21 Plumbing 5 07-02-2008 09:46 AM
dual shower heads canadaclub Plumbing 2 03-06-2008 06:11 PM
shower heads dgordon1979 Plumbing 2 09-28-2005 09:02 PM
