Multiple Fixtures On 2" Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2017, 12:35 AM   #1
Rewards Points: 8
Multiple fixtures on 2" pipe
Is it possible to have a wash machine, shower and bathtub on a 2 inch pipe
woodsf is offline   Reply With Quote
Old 01-17-2017, 08:14 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,184
Re: Multiple fixtures on 2" pipe
I am guessing you are referring to a drain line?
Will they ever really be used concurrently?
Old 01-17-2017, 08:56 AM   #3
Rewards Points: 8
Yes, a drain line.
It's possible for the shower/tub to be draining when the washer is draining.
Old 01-17-2017, 09:13 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 770
In my state, yes. However, since codes vary state to state, I recommend you ask your local authority. I'm sure you are undersized in some states....
Sent from my HTC6525LVW using Tapatalk
Old 01-17-2017, 10:18 AM   #5
Rewards Points: 854
Laundry and a tub draining to the same line will need a 3" drain line and I believe a 2" vent.
clarenceboddick is online now   Reply With Quote
Old 01-17-2017, 05:11 PM   #6
Rewards Points: 2,030
Missouri follows the IPC code so your answer is once the washer drain has a second fixture the line will need to be sized to 3 inch. Also you will need to individual vent all fixtures involved.
406.3 Waste connection. The waste from an automatic clothes washer shall discharge through an air break into a standpipe in accordance with Section 802.4 or into a laundry sink. The trap and fixture drain for an automatic clothes washer standpipe shall be a minimum of 2 inches (51 mm) in diameter. The automatic clothes washer fixture drain shall connect to a branch drain or drainage stack a minimum of 3 inches (76 mm) in diameter. Automatic clothes washers that discharge by gravity shall be permitted to drain to a waste receptor or an approved trench drain.
FIXTURE DRAIN. The drain from the trap of a fixture to a junction with any other drain pipe.
FIXTURE BRANCH. A drain serving two or more fixtures that discharges to another drain or to a stack.
Ghostmaker is online now   Reply With Quote
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
Can I use 2" sanitary pvc pipe below new toilet? toggenburg Plumbing 15 01-27-2012 07:47 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 07:49 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
