Mueller Faucets - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-24-2012, 11:21 AM   #1
Mueller Faucets
I am trying to remove the seat on a mueller bathtub faucet and am having issues . i can get the handle and everything else off until i get to the valve and then i hit a road block . I need advice on how to get into it as i have very low pressure and need to see if the valve is obstructed. is it even possile to emove te seat on oe of these faucets
Donpol is offline   Reply With Quote
Old 06-24-2012, 03:34 PM   #2
Rewards Points: 3,628
Ask Mueller,i'm sure they can tell you.
http://www.muellerindustries.com/pro...umbing/faucets
Canarywood1 is offline   Reply With Quote
Old 06-24-2012, 03:54 PM   #3
DIY staff
Rewards Points: 7,174
Post a picture if you can--that is not a popular brand in this area--Need picture of the stem and cap nut.
Old 06-24-2012, 05:50 PM   #4
Thanks everyone I did a bit of furthar checking and dont beieve the problem is in the Faucet set. The pressure is low through the entire hotwater system rom the hot water tank on so if anyone has any ideas I am open to suggestion
Old 06-24-2012, 06:08 PM   #5
DIY staff
If the water was shut of at the hater heater recently---and you have a gate valve (round handle)
I would suspect that the gate valve has broken in the 'off' position---happens a lot--
Has anything been done to that heater recently?
How do I unclog water lines, faucets? anuvanoob Plumbing 13 12-20-2015 01:35 PM
Warm water coming from cold faucets ygillard Plumbing 2 03-02-2012 02:24 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
No Hot Water comeing out of Faucets gangstacro Plumbing 5 11-30-2008 03:32 PM
Repair/Rebuild antique faucets bofusmosby Plumbing 8 11-25-2008 05:59 PM
