Is A Mud Bed Recommended For Acrylic Tub Installation? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2008, 04:40 PM   #16
TMIV, you are not actually "filling every void". You are merely adding support to the bottom of the tub to prevent flexing. As long as you have a solid base across most of the bottom, it will do what it is supposed to.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-20-2008, 06:17 PM   #17
BUILDER / REMODELING CONT
buletbob's Avatar
Originally Posted by Boston Plumber View Post
Hi JayP:
If you can be sure the tub sits perfectly level on the floor, or if you can shim level, then glueing will work fine.
However, if like most remodel jobs....things are out of plumb/square....so I would set this unit in a bed of modified thinset mortar or on a bed of structolite gypsum plaster (make sure you have a plastic sheet (garbage bag) on floor before pouring these substrates).
I follow the FOOTPRINT of the tub base and then add 1-2 inches more than I think I need, then lower the tub into the substrate, level front to back and side to side, then I screw the unit into the studs.
Then I fill the tub 3/4 of the way for 24 hours or until substrate dries (simulates person getting in tub for bath...so less fluctuation/flex later).
I am a big fan of the structolite gypsum plaster...dries in 24 hours or less (NOT REGULAR PLASTER or joint compound here...can breed mold). It is available at most home supply stores or at a plaster supply house!!
Anyway...I would set it into some substrate...unit will make less noise when stepping into it, water will stay warmer longer (insulates tub base), and noise from showers will be reduced through the walls/ceiling!!
Good luck!!
We use the structolite gypsum plaster all the time, with the same principle as stated above with excellent results, BOB
Old 09-20-2008, 10:42 PM   #18
Sorry, but I have a problem with filling the tub (acrylic type) with water while the mud is drying. When you release the water, the tub will go back to the original shape and leave a gap between the mud and the tub bottom. This would just make an area where the tub would eventually crack since it would move each time someone stepped into it. The only time I add water is when I redo a bad caulk job around the edges.
Old 09-22-2008, 09:10 AM   #19
Rewards Points: 156
yes
Yes -- exactly what he said. Never add water while the mortar is drying. You're defeating the purpose which is to not allow the tub to flex. As for the bed itself, you don't really need that much mortar. Trust me, if you add too much you'll find out how big of a pain it is to flatten it out underneath the tub.
Just scoop it into a pile that is sort of long running from around the drain opening to the back where the tub starts to curve upward. Then put the tub in and rock it around till the tub is sitting flat. MAKE SURE you don't get any mortar underneath the feet if your tub has any sort of feet that are supposed to touch the floor. You'll want to adhere them with construction adhesive.
jayp is offline   Reply With Quote
Old 09-22-2008, 11:20 AM   #20
The instructions to my tub say to "completely fill the space between the tub and the floor" and "Put eight to ten inches of water in the tub to hold it down." So I guess in some cases it is required. You can check out the instructions for yourself. Check section 4 - Setting the Tub
TMIV is offline   Reply With Quote
Old 09-22-2008, 12:01 PM   #21
TMIV. Your instructions seem to be for a whirlpool tub. It also mentions supports on the bottom of the tub. Many tubs do not have these. Your tub company also describes two different types of installation. Drop-in, and 3 point with flanges. Your tub could be one of few exceptions if it is the drop in type, since there would be nothing to hold the tub in place while the mortar cures. The 3 point is secured to the walls through the flanges and supported by boards attached to the walls for keeping it level. This would negate the requirements for filling the tub with water. Since you would be voiding a warranty by not following the instructions, you need to do that. I was not thinking of a drop in tub when I replied to the post (my fault).
Old 09-22-2008, 06:37 PM   #22
buletbob's Avatar
Your correct, I should read through the post I quoted, I fill the tub when I'm caulking the tub. I stand to be corrected. Thanks guy's
Old 07-17-2009, 02:48 PM   #23
Is the bath supposed to stick to the mortar, or just sit in it. I put a mortar base in, but within 24 hours the bath seperated - therefore has a hollow feel to it. Why not sandwicch expanding foam between mortar base and tub? ( my plumber insists that the bath doesn't need to stick to the base)
SPIDERBRAD is offline   Reply With Quote
Old 07-18-2009, 01:02 AM   #24
Man of many hats
wrangler's Avatar
Rewards Points: 354
It should not have separated unless weight was added to it before it was allowed to set. When we set tubs/shower pans, we use 20-45 minute gypsum, level the pan/tub and screw it into the studs and allow it to set up before walking on/in it. This is important if not to ensure that the tub or pan is level for doors and for the very problem that you stated... if you walk on it before setting, it will push out the underlayment and create cavities. Expansion foam can create uneven spots or raise the tub/pan out of level and cause even harder problems to deal with later(such as leveling doors).
Acrylic tubs should be test fit first, with the ledger board installed, and plumbing verified. If satisified, then pour the bed, set the tub, level, screw off and allow to set for the curing time. Same for acrylic pans, less the ledger board. Then finish drain connections (screwing compression fitting for pans, over-flows and shoe for tubs) and work your way on up the walls. This varies a bit if doing whirlpools or jetted tubs as they often require the electrical work first, and added carpentry to set the tub into.
If working with code inspectors, some of this requires step-by-step inspections but, after repeated jobs, some inspectors will let you get by with detailed pictures of each step of your remodel as long as there is still access to wiring and plumbing connections (in some jurisdictions).
But I digress... your bed was not, nor should not have acted as an adhesive, but more of an obstruction to downward movement of your tub. You could leave it as is and hope that it lasts as long as your use requires, pull it up and redo it, try to add more bedding or even 'expansion foam' as you suggested, but personally, unless it was moving alot or is a really cheap tub, I think I would leave it as is.
Man of many hats
wrangler is offline   Reply With Quote
Window installation cost only. Changeling Building & Construction 18 06-30-2008 02:01 PM
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 12:15 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
Window Well Installation Bill46 General DIY Discussions 1 04-03-2007 04:49 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
