Mowed Over My Septic Vent, What Next? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-30-2011, 07:15 AM   #1
Unhappy
Mowed over my septic vent, What next?
This is what I believe is a gas vent for the septic, looks like there was a pvc pipe in a metal pipe caped with a mushroom top, which is bent a bit. Is it as simple as buying a new pvc, cutting to size and putting the mushroom cap back on it and it will be as it was before I ran it over with the mower? Should I be concerned with anything getting into the pipe? Can I get another mushroom cap or try to reshape and put back on?
ccz1968 is offline   Reply With Quote
Old 05-30-2011, 07:44 AM   #2
DIY staff
Rewards Points: 7,174
Any possibility of a picture? You should be able to fix that easily---Just need a better idea of that vent.
Old 05-30-2011, 08:50 AM   #3
Civil Engineer
Rewards Points: 4,782
The septic vent is normally a simple repair, you get a new one, and glue it in place, else use a coupling. Done deal. Get it fixed before a skunk moves in.
Septic Tank Vent Pipe ddave23 Plumbing 32 04-25-2017 07:06 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
Air admittance vent with septic system. Roy Rowlett Plumbing 4 06-14-2010 09:53 AM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
