Moving Water Softener... - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2008, 02:25 PM   #1
Rewards Points: 77
Moving water softener...
I am finishing my basement and my problem is that my water softener was put in a bad spot. My incoming water line is in the corner of the basement. I would like to run that line to the center of the basement near the water heater and furnace since that area will stay unfinished. Are there any codes or anything that I have to worry about? I know to keep 30" clear from the front of the furnace, but can I put the softener anywhere else, like behind the furnace or next to the water heater?
epeterson777 is offline   Reply With Quote
Old 09-07-2008, 11:03 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
There should be no problem with moving it there. Double-check with your Building Inspection Department for local codes, permit and inspection requirements, etc.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
Fleck Water Softener not softening & too much water in brine tank april66 Plumbing 2 02-01-2010 11:12 AM
Water Softener wont stop draining help TTran Plumbing 3 08-24-2008 08:16 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
