Moving Washer To A New Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2007, 10:52 AM   #1
Moving washer to a new location
I live in a house that was built in 1929 and I'm moving the washer from the kitchen into another area. Do I need to install a vent that runs up the wall and out the roof?
CaseyPledger is offline   Reply With Quote
Old 03-25-2007, 11:19 AM   #2
Eibwen
Are you moving the washer to a new loaction that has no drain now and plan on installing one? If so, I would say yes or the drain will not flow properly.
Sammy is offline   Reply With Quote
Old 03-25-2007, 11:22 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Yes, connect a 2" line with a trap at the bottom of the washer standpipe with a vent after it. You can vent it out the roof, or tie it into another vent stack if possible. If local code allows them, you might be able to install an air admittance valve in lieu of a normal vent.
If a utility sink is near the new washer location, you also could discharge the washer into that since its already trapped and vented.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-25-2007, 12:01 PM   #4
Yes, I'm moving it to a new location that doesn't have a drain yet. Thanks for the great information.
noisy washer agitator bucksone Appliances 43 03-06-2014 08:49 AM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
moving gas dryer sonofthetonsured Appliances 12 07-07-2007 11:56 PM
Moving washer/ dryer from 1st to 2nd floor sebastien1 Remodeling 33 11-08-2006 10:31 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
