Moving Washer/dryer, Etc. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2010, 01:30 PM   #16
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
A gas washer -- I don't think so. You need a 20 amp GFCI receptacle for the washer. Rerouting the gas for the dryer through the crawl space should not be a big deal but I would get a certified gas installer(or plumber) to do the work. You will need permits for the electrical and plumbing.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-29-2010, 05:37 PM   #17
Is it a complex process to extend the gas service to the wall where the new hookups will go?
Usually extending/re-routing a gas line is no big deal. As for the drainage and all the rest of the underfloor work, the operative word in all of this is CRAWL space. It just slows everything down.
VIPlumber is offline   Reply With Quote
Old 12-29-2010, 08:47 PM   #18
Picky Plumber
The washing machine/ dryer connections should be a somewhat easy task. Just make sure it's done right. The dishwasher can be supplied from the hot water stubout under kitchen sink and the drain can tie into the tubular or the disposal easily. Make sure you have plenty of access to the front of the furnace and the water heater for service and replacement purposes and also for safety from combustable building material. An alteration such as this should be permitted and be installed to current code. Make sure if you're doing this yourself to check on current requirements. If hiring a pro, make sure they have a good reputation and that you feel comfortable that they know what they're doing.
Plumber26 is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Moving a support post RaH Building & Construction 5 03-07-2010 08:48 PM
Moving washer/dryer from basement to 2nd floor DIY newbie Appliances 3 02-14-2010 07:38 AM
Kitchen backsplash with moving foundation khaecker Remodeling 5 06-07-2009 01:50 AM
How to handle circuit for washer/dryer relocation? KUIPORNG Electrical 9 06-16-2006 09:09 AM
