-   -   Moving washer and dryer? (http://www.diychatroom.com/f7/moving-washer-dryer-126948/)
bassadict69 12-18-2011 11:53 AM
We recently bought a new front loading washer and dryer and due to them being a little larger than our old one, we had to move stuff around a little in our utilitly room so we could slide them down enough to open the door to the utility room.
On another wall of the same room is our water heater which sits in a corner (of outside walls), I would like to move the washer to one side of it and the dryer to the other. We could tie into the lines for the water heater to supply the washer and we would vent the dryer through the outside wall.
Question is, can the washer drain line be tied in to the drain of a sink which sits next to where the washer would sit?
I hope I explained this well enough to answer...
plummen 12-18-2011 12:42 PM
if its one of those big wash sinks/tubs you can normally drain into the sink,otherwise a washer requires its own 2" drain to keep up with it :)
ben's plumbing 12-18-2011 07:37 PM
it would help to have picture of sink.....
bassadict69 12-19-2011 11:16 AM
Here are a couple of pics of what I am working with...I am wanting to put the washer where the freezer is and the dryer on the wall on the other side of the water heater.
http://i5.photobucket.com/albums/y15...9/PC190137.jpg
http://i5.photobucket.com/albums/y15...9/PC190136.jpg
http://i5.photobucket.com/albums/y15...9/PC190138.jpg
plummen 12-19-2011 11:46 AM
no that sink will not work as a catch basin for washing machine,needs to be a wash tub type sink to catch the water.
the plumbing running to that sink is also too small for washing machine :(
ben's plumbing 12-19-2011 07:01 PM
no no no agree with plummen this is way to small to handle water discharge from washer....what are your other options as far as plumbing lines and their locations.....sorry
Wife DIYer 12-19-2011 11:07 PM
Would you be able to change out the sink to a wash tub type? Then you could just hang the wash waste water hose clamped to the side of the tub sink. My mom had that arrangement when I was growing up, (she had a cement tub sink).
bassadict69 12-20-2011 11:06 AM
If it comes down to it, we may have to do just that!
Anyone know what this pipe is coming up from the floor? It looks like some sort of drain or vent?
http://i5.photobucket.com/albums/y15...9/PC200142.jpg
ben's plumbing 12-20-2011 08:41 PM
that looks like a drain or a vent...but if it was a vent the fact its closed off you would be having so kind of problem...my guess a drain....take off tape fill sink bowl with water and drain it..listen in 2" pipe to see if you hear water...that will tell you if its part of the system if it is there is your washer drain...
bassadict69 12-21-2011 12:22 PM
I removed the tape, pulled the plastic cap and sure enough...there is water down there! :thumbup: I did as you said, and sure enough, it is a drain! That will definitely make this little move a lot easier! I am assuming it will handle the water?
Next question, rather than solder in valves into the copper lines at the water heater, is it ok to use the shark bite stuff?
ben's plumbing 12-21-2011 03:51 PM
Iam not a big fan on this stuff...only because I like copper and Iam very good at it....but yes alot of diy use it seems to be ok... good luck...:thumbup:
md2lgyk 12-22-2011 07:23 AM
I'm sure a pro will chime in here, but I don't think that is legal any more.
VIPlumber 12-22-2011 08:38 AM
It's still accepted practice around here.
It's probably the drain for the T&P relief valve.
bassadict69 12-24-2011 01:45 AM
T & P?
I am looking into both routes, using the shark bite stuff to tie into the lines and also looking at getting someone to solder into the lines and do it right!
I am planning to hopefully get my electrician buddy to run the electric for them this weekend and I plan to try to remove some bricks to make room for the dryer vent. I have never done that before so any help would be great! I plan to just air chisel the mortar to remove them.
VIPlumber 12-24-2011 10:51 AM
T & P?
Temperature & Pressure relief valve, here's a pic of what one looks like.
http://hotwater911.com/wp-content/up...1-TP-valve.jpg
