Old 08-09-2012, 08:43 PM   #1
Moving a vent in the wall.
I am installing a sliding glass patio door in my kitchen. The door that is there now is NOT a sliding door. So... Gotta cut a new hole in the wall and new header and studs. Blah, blah. That's not the problem. I tore into the drywall in the kitchen and realized very quickly that there is a vent pipe in the middle of where the door needs/has to go. I am NOT going to start a roofing project to move this vent's exit location. What are my options. Keep in mind that there will be a 2x12 header where the vent goes up the wall and to the roof. This is a two story house. I will try to send pics. if needed.
deb0815 is offline   Reply With Quote
Old 08-09-2012, 09:00 PM   #2
biggles's Avatar
if it is PVC elbow away from the sliding door then come acrss the top to reconnect to the exsisting vent riser... if there is a basement relocate where it rises into the kitchen then up elbow over the top of the slider..even consider bush it down for the trip around the slider..just throwing out stuff...might be a law in your state that you can't size down a vent riser..forget the roof it's do able inside totally
Old 08-09-2012, 09:02 PM   #3
call me E
TheEplumber's Avatar
The vent needs to exit through the roof. 2 ways around it- use an AAV on the fixture in the basement and eliminate the vent-assuming they are allowed by your local code. Or reroute the vent to tie into another vent stack.
The Following User Says Thank You to TheEplumber For This Useful Post:
jaydevries (08-09-2012)
Old 08-09-2012, 09:05 PM   #4
Is an AAV a one way check valve?
Old 08-09-2012, 09:11 PM   #5
call me E
Do a google search for studor vent or AAV
I recommend trying to reroute the vent first.
deb0815 (08-09-2012)
Old 08-09-2012, 09:25 PM   #6
Checked out AAV. That was what I was looking for. And it's within code! You guys rock!
Old 08-09-2012, 10:08 PM   #7
Doing it myself
Alan's Avatar
Journeyman Plumber
Old 08-09-2012, 10:10 PM   #8
call me E
Be careful with those things. I hate them, as does my inspectors. If we can vent in a typical method (no matter how difficult)- we do.
Old 08-10-2012, 12:32 AM   #9
Doing it myself
Alan's Avatar
I think someone should put a censor in for AAV and studor vent on the forum.
Journeyman Plumber
Old 08-10-2012, 10:27 PM   #10
Yup. I did more research. I won't be using an AAV. I always want to do the right thing and you reminded me of that. Thanks guys.
Old 08-11-2012, 08:22 AM   #11
I don't get the hostility toward AAVs. They serve a legitimate purpose if a fixture can't be vented any other way, and are perfectly legal (here anyway). My kitchen sink is vented with one, and there has never been a problem.
Old 08-11-2012, 11:54 AM   #12
Doing it myself
Alan's Avatar
Know how many times i've seen that in 5 years?
I can count them on one hand.
Journeyman Plumber
Adding a wall vent connected to utility room exhaust findlay70 HVAC 0 02-23-2012 12:29 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 07:58 AM
Direct Vent Wall Furnace - Pilot-Help !! roztom HVAC 4 04-28-2010 11:25 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
