Old 09-12-2012, 07:59 PM   #1
moving a vent pipe
Is there any reason that I could not move the vent pipe [center] in the below picture to one of the two circled areas on the left?
That cast iron T is the drain for two upstairs showers as well as the pictured shower and down stairs sink [ horizontal section of pipe]
hellonoko is offline   Reply With Quote
Old 09-12-2012, 08:12 PM   #2
call me E
TheEplumber's Avatar
moving a vent pipe
You really shouldn't lay the vent horizontal below the slab although it is done sometimes. Is that what you want to do? Or do you want to move the point that the vent connects to the drain? You can move it downstream but not beyond the wye- at least by my code.
Old 09-12-2012, 08:38 PM   #3
moving a vent pipe
@TheEplumber - I won't be laying it below the slab - I will keep it in the same configuration just change it's location to the area of the wye-
Old 09-12-2012, 08:41 PM   #4
call me E
moving a vent pipe
you need to keep it on the branch line
Old 09-12-2012, 08:42 PM   #5
moving a vent pipe
So as long as it stays on the line that goes to the lower level shower drain (the one im building in the picture) I am ok?
Old 09-12-2012, 08:45 PM   #6
call me E
moving a vent pipe
If the second picture is your lower shower- yes, the same line that has the ptrap
Tags
plumbing, shower, vent
Frozen Vent Pipe Ratchye Plumbing 32 12-12-2012 10:56 PM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 09:29 PM
Vent pipe - horizontal? secutanudu Plumbing 3 03-02-2011 07:23 PM
Shop heater, gas pipe in contact with vent Richo HVAC 15 02-05-2011 11:28 PM
Insight on framing inset and rerouting vent pipe drcheap Remodeling 7 01-13-2011 04:15 AM
