Moving A Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2012, 04:59 PM   #1
Moving a vent
I am currently doing a bathroom. My wife wanted a light fixture which requires a octagnal box. Currently I had a square box with a vanity strip which the builder installed probably against code on the opposite side of the stud I want to put my octagonal box on. The vent runs through this stud area in my way for my box. My question is can I re rout this in the wall with lets say 3 x 45 elbows? If so would I use a union to re attach or just a coupling and try to move it? Here's a pic. It's looks like 1 1/2".
RegLearning is offline   Reply With Quote
Old 03-03-2012, 05:49 PM   #2
Rewards Points: 636
why when you can use a pancake box or a saddle box and be done like one of these in link
http://www.lowes.com/LowesProductCom...les_dollar%7C1
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-03-2012, 05:53 PM   #3
DIY staff
Rewards Points: 7,174
You may put a set of fittings together to give you the room you need---to make things easier use one rubber Fernco fitting--that's a rubber 'boot' with two hose clamps--the other 90s or 45s can be glued fittings.
Vent pipes must be able to drain so do it in such a way that no water can get trapped in a low spot--
Birds bathroom vent mess Wheats General DIY Discussions 0 11-28-2010 08:04 AM
Vent for basement bathroom group chadmills Plumbing 1 10-29-2010 03:03 PM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 12:34 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
