Moving A Toilet Over. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2011, 09:06 PM   #16
Yes, the drainage portion of the basin will act as a vent, not the basin itself, it is called a wet vent. The vent still has to be brought to open atmosphere through an existing vent, or if you are allowed, the vent I spoke of earlier.
The way the basin was installed originally is completely wrong, the 90 above ground for the basin should have been a ty with the top of the ty going to a vent somewhere.
I may also be wrong on the 2" drain size for a wet vent, it is required where I am but was only changed a few codes ago, we were able to use 1-1/2" in the past, you will have to find that one out locally.
Dougtheplumber is offline   Reply With Quote
The Following User Says Thank You to Dougtheplumber For This Useful Post:
plumberbear (01-09-2011)
Old 01-09-2011, 09:13 PM   #17
This pic should help.
Old 01-09-2011, 09:51 PM   #18
we are allowed to use air acceptance valve in new york. 2" for drain pipe is right. thank you so much
plumberbear is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
moving toilet. Kaveran Plumbing 1 05-22-2009 07:46 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
moving basement toilet cibula11 Plumbing 10 10-20-2007 01:22 PM
Moving Toilet cibula11 Plumbing 5 02-19-2007 08:47 PM
