Moving A Toilet Over. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2011, 02:32 PM   #1
moving a toilet over.
hi every one, i need help on how to move a toilet over. i am attaching some pics to help everyone out. need to move it over about 2 feet to the left. all materials and advice would be appreciated. if more info is needed please let me know. thank you.
plumberbear is offline   Reply With Quote
Old 01-09-2011, 04:15 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
where's the vent?
In theory, moving the drain over a few feet to the left is easy. Cut the copper, get a copper-to-pvc adapter (generically called a Fernco, but Fernco is just one specific manufacturer of such products), and replumb whatever you need with PVC, which is easy to work with. However, I don't see a vent anywhere. Also, is the copper drain pipe only 2", or is it actually 3" and is just deceptive looking?
Do you know if your main stack is right behind the wall, behind that cleanout? If it is, then that is your vent, which solves the venting issue.
adpanko is offline   Reply With Quote
The Following User Says Thank You to adpanko For This Useful Post:
plumberbear (01-09-2011)
Old 01-09-2011, 04:30 PM   #3
Start by stripping all of the copper plumbing out as it has been installed incorrectly. It looks to me that the brass fittings are incorrect as they have used what is called a TY instead of proper Wye fittings, this includes the 3" fitting off the main. TY fitting cannot be used on horizontal piping in drainage, only in venting.
I cannot tell what the smaller copper line off the side is for, but it is also off of a TY fitting, not to code.
I cannot see what the PVC line that goes to the left is tied into or what fitting is used off another pipe.
Better to just start over as there is really not much more work and it would be completed properly.
Make sure that you have the toilet vented, perhaps through the pvc line. In my area the size of vent needed is 1-1/2" by itself or 2" if the toilet vent is acting as a drain for another fixture.
The fernco coupling that adpanko talks about is already installed in your floor, only yours is a smaller one than he is refering to, just to give you an idea.
Dougtheplumber is offline   Reply With Quote
The Following 2 Users Say Thank You to Dougtheplumber For This Useful Post:
oh'mike (01-09-2011), plumberbear (01-09-2011)
Old 01-09-2011, 07:21 PM   #4
thanks for taking the time to help me out. i knew this was ugly when i ripped up the flooring. first, yes the drain pipe is 3", and there was no venting. no vent pipe by clean out. the smaller copper line is the drainage line for the sink. should change to pvc i think. the pvc line that you see going to the left was for a shower, i took it out.
so the ty looks like wye fitting of the main line. just replace everything after it? not sure how im going to vent this. could you draw me up a diagram of how the connection to the toilet would look like? thank you.
if i have missed anything, please let me know.
Old 01-09-2011, 07:31 PM   #5
this is wye i was talking about, its not a ty, right. thanks.
Old 01-09-2011, 07:38 PM   #6
Experienced
Jackofall1's Avatar
When looking at the last picture posted, where does the 3" line continue to (to the left)?
Old 01-09-2011, 08:01 PM   #7
to the clean out.
Old 01-09-2011, 08:19 PM   #8
Experienced
Jackofall1's Avatar
In the last pic posted which way do you want to move the flange?
Where is the stack from upstair? anywhere near?
What is above this bathroom?
Just trying to figure a vent
The Following User Says Thank You to Jackofall1 For This Useful Post:
Old 01-09-2011, 08:20 PM   #9
Yes they are all TY's and they are not to code.
Old 01-09-2011, 08:25 PM   #10
Actually moving the toilet farther away will make it easier to plumb as it is quite difficult to do properly in tight quarters with no room for the proper fittings.
Is the basin staying in the same location?
Is there a shower going back in or are you staying with just a toilet and basin?
The Following User Says Thank You to Dougtheplumber For This Useful Post:
Old 01-09-2011, 08:33 PM   #11
I want to move it in the direction of the white pvc pipe. above this bathroom is the bedroom. the stack for upstairs is in the middle of the house,and about 20 feet away.
Old 01-09-2011, 08:36 PM   #12
no more shower, staying with the toilet and the basin is staying in the same location.
Old 01-09-2011, 08:49 PM   #13
I have tried to attach a file on the rough in, I hope it works.
Old 01-09-2011, 08:56 PM   #14
There is not enough information available to help you with the vent at this time, but basically when the basin drain rises up through the floor, you will install a 2 x 1-1/2 x 1-1/2 TY (they are legal on vertical piping, not on horizontal). The side inlet of the ty will be the drain for the basin, the top inlet will be the vent. You have to find a vent in the area, even 20' away, that you can tie into.
I am not sure of the legislation in your area, but our code allows an air acceptance valve only when a proper vent is not reasonably achievable.
Old 01-09-2011, 08:57 PM   #15
this looks great, my basin will act as my vent? i really appreciate you taking the time to do this for me.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
moving toilet. Kaveran Plumbing 1 05-22-2009 07:46 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
moving basement toilet cibula11 Plumbing 10 10-20-2007 01:22 PM
Moving Toilet cibula11 Plumbing 5 02-19-2007 08:47 PM
