Moving A Toilet In Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2008, 05:16 PM   #1
Moving a toilet in bathroom
What kind of issues will I need to address if I want to move a toilet in a large bathroom?
Here's what I want to do.
------------------- <- outside wall of house
| x(toilet) |
| x |
| **(new spot) |
floor joist run --->
this way
I would like to move the toilet from it's present spot(xx) on the outside wall, across the bathroom(**) and turn it facing along the front wall of the bathroom. We would like to make the shower bigger and this would give us plenty of room. The toilet would be moved about 6 ft or so.
Can you relocate the drain that far? Will there be an issue with having enough fall or pitch in the drain pipe? Can you just extend the vent for the toilet from its original place? I'm sure there are other issues I don't know about. There's no problem in removing the floor to do the framing and plumbing.
Thanks, Randy
randalg is offline   Reply With Quote
Old 01-17-2008, 06:47 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,732
Ayuh,.....
Without knowing Where the pipeing runs to/ from,.....
Answers to your questions are going to be tuff to find.......
Depending on Access,+ What's there Now,.....
It may or may Not be doable...........
Bondo is online now   Reply With Quote
Old 01-17-2008, 06:17 PM   #3
Send a message via AIM to Marlin
We need much more information to answer your questions.
Marlin is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 01:22 PM
Moving a bathroom mirror iOsiris Remodeling 3 08-28-2007 12:20 PM
Moving Toilet cibula11 Plumbing 5 02-19-2007 08:47 PM
moving toilet farrington135 Plumbing 5 11-19-2005 04:29 PM
