Moving The Sink From One End Of The Kitchen To The Other? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2011, 03:06 PM   #1
Rewards Points: 150
Moving the sink from one end of the kitchen to the other?
Iwill have NO problem moving the 1/2"copper water lines fromone end to the other,(read as I know how and can solder) my question is the drain? How much pitch do I need. There shouldn't be any issues because the laundry/hallway next to garage is directly underneath kitchen and all open. I am just unsure how much pitch I need for proper drain? And IF I am oversimplyifying this PLEASE let me know! If I over looked something or whatever! THANK YOU
Evil Scotsman is offline   Reply With Quote
Old 03-21-2011, 04:52 PM   #2
Homerepairguy's Avatar
Rewards Points: 990
My understanding is that the ideal pitch for a waste drain is 1/4" per foot. For a toilet, 1/4" per foot allows moving the solid waste down the drain properly. Too much or too little pitch can impede movement of solid waste. For a kitchen, I would also use 1/4" per foot since a garbage disposal might be installed and I would want that waste, albeit much smaller than toilet waste, to move along nicely.
HRG
Homerepairguy is offline   Reply With Quote
Old 03-22-2011, 12:56 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 358
A drain line for a kitchen sink should be 2" dia. graded @1/4" per ft. with a clean out installed at its upper terminal. The trap arm can be 1 1/2" and the p trap must be vented.
If you move the drain across the room, how will you vent it?
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 07:33 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 10:16 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 12:01 PM
Kitchen sink jonnyjonny_uk Plumbing 6 11-20-2006 07:43 AM
