Old 11-09-2009, 07:06 PM   #16
Master General ReEngineer
Moving sink Drain
Originally Posted by Anti-wingnut View Post
Originally Posted by Claire Keila
Your trap is probably backed up. You have to go under the sink and disconnect the drainpipe coming out of the bottom of the sink. You will see that that pipe connects to another. That is where the trap is. It traps hair & stuff. It will be slimy, smelly & gross. Once you remove that & rinse the pipes out thoroughly, reconnect them. Use a thin tape called 'pipe dope' around the male part that screws into the other. This prevents the connections from leaking. Your drain won't back up anymore & the smell will go away. When you do this have a bucket and a towel that you use as a rag. When you are finished & test it, turn water on slow and put bucket & towel underneath in case it leaks.
Did you look at the photographs? The cabinet, lav, and trap have all been removed. The OP is concerned about how to re-locate the wall fitting. We are here talking about apples, while you're in left field mumbling about oranges
Ayuh,... That's Not a reply gentlemen,... That's jusy plain ole Spam,...
Claire is selling SSteel Sinks...
Last edited by Scuba_Dave; 11-09-2009 at 07:35 PM. Reason: quoted spam link deleted
Old 11-09-2009, 07:37 PM   #17
Extreme DIY Homeowner
Scuba_Dave's Avatar
Moving sink Drain
Yup Claire is (was) a spammer from India
They are actually not Spam bots - but Spam People
They are paid to post links all over the web
If you see something like this please report the post so we can Ban the spammers
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile (User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
Scuba_Dave is online now   Reply With Quote
Old 11-18-2009, 09:47 AM   #18
Moving sink Drain
Well, I ended up using a flexible Fernco coupling. I raised the pipe's pitch some to get the proper drop (actually more than the 1/4 drop per foot required by code). The copper drain pipe I removed was full of junk-probably due to the incorrect drop. Here's a pic of my completed work. I moved the water lines and put 1/4 turn compression valves on. I also added some GFCI outlets and put up the drywall. Taped last night. Hope to put final two coats on by this weekend, prime, texture, prime and paint.
knighton is offline   Reply With Quote
More On This Topic
How to Unclog a Sink Drain
How to Unclog a Sink Drain by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through step to for making our sink drain better. Our next step is to remove this portion of that P trap to this I'm going to loosen both of these collars that holds the... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through step one in making a sink drain better. The first thing we need to do is identify the problem when this sink fills up the water takes a very long time to drain out... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
My name is Jeff Pence I'm with Bob Street today from Houdini Home Improvement Lebon, Ohio on behalf of Expert Village. In this clip we'll be assembling the P trap and attaching it from the stopper valve assembly to the sewer pipe in the wall. We need to... Read More »
Help moving kitchen sink pflaxman Plumbing 2 09-22-2009 01:19 AM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 08:31 AM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
