-   -   Moving sink drain (http://www.diychatroom.com/f7/moving-sink-drain-159091/)
wwkayaker 10-05-2012 05:30 PM
Moving sink drain
I am replacing by vanity and the sink will be positioned about 8 inches to the right. Can I use an extension to attach the new sink to the current drain line?
VIPlumber 10-05-2012 09:06 PM
Sure you can provided the new sink is the same depth as the old one and you can maintain the proper slope of 1/4" per foot.
wwkayaker 10-08-2012 12:10 AM
I have been rethinking my drain assembly and I need to clarify my plan. So, the tailpipe comes straight down into the ptrap. The ptrap is 8 inches to the right of the waste pipe. After the ptrap, can I use a 45 or 90 elbow or two to connect the extension to the waste pipe? I think by cutting the waste pipe shorter and adding a 45, i should be able to run an extension from the 45 into the ptrap.
I read about code being no more than one slip joint between the ptrap and waste pipe and I am unsure if that applies to what I am trying to do. For what it's worth, although I would be using an angled joint, I am not planning to change the horizontal run from the ptrap to include a vertical section which I think would make an s trap which I have read are illegal.
Thanks.
TheEplumber 10-08-2012 09:20 AM
199 Attachment(s)
Thanks.
Yes you can use the fittings and offset the trap arm but use pvc/abs with glued fittings- only 1 slip joint allowed in the horizontal
wwkayaker 10-08-2012 11:05 AM
Thanks, it makes sense to me now.
