Moving Roughed In Shower Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2011, 09:11 AM   #1
Moving roughed in shower drain?
How difficult would it be to move a shower drain? The builder roughed in the drain but with the xps and then the frame wall in front, that only leaves enough room for a 30" deep shower stall. I would like to move it about 4" so we can fit a deeper shower in there. My other option would be to remove the framed wall section where the shower would be and just use furring strips in that area with some more xps to up the R value. That would give me a couple extra inches.
NEW-B is offline   Reply With Quote
Old 04-05-2011, 09:56 AM   #2
Owner
LateralConcepts's Avatar
Is it on a slab or do you have a crawl space?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 04-05-2011, 10:55 AM   #3
Slab, 1 year old basement.
Old 04-05-2011, 11:10 AM   #4
Owner
Ok, so to answer your question... "How difficult?" That depends on what you consider difficult. It's fairly simple, but will require jack hammering or saw cutting the concrete to expose the line. Once it's exposed, it's just a matter of re-configuring the drain depending on how it's laid out. That's the easy part.
Lateral
(208) 818-8241
Old 04-05-2011, 11:56 AM   #5
Doesn't sound too bad. I'll probably break a small section around the drain so I can see where the pipe is laid out and go from there.
Old 04-07-2011, 09:05 AM   #6
Well I decided against breaking up the concrete. I found that I can still fit a 32"-34" deep shower depending on the drain placement. Sounded easy enough, but I didn't want to have to break it if I didn't have to.
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-21-2010 11:45 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Solution for 1.25" drain pipe for removable shower? CZ DIY Plumbing 3 10-06-2009 10:20 AM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
