Old 01-16-2009, 09:42 PM   #1
Default Moving Plumbing
I'm remodeling our bathroom. The sink is in a different place so there are two supplies that run from the tub that will not be used. I have to run the tub supply to a different location. Do you recommend I change what was a T to an elbow and just connect the tub or can I just cut the cooper tubing below the floor and cap it off?
I also plan on using shark bite to run from the existing copper to pex tubing because it will be a lot easier to get it through the floor and into the shower wall. Any thoughts/concerns????
MikeyP is offline   Reply With Quote
Old 01-17-2009, 03:15 AM   #2
Building codes guy, Mod
thekctermite's Avatar
Your plan for moving the pipes sounds fine. I'd terminate any lines that aren't going to be used as opposed to capping however.
The Sharkbite fittings are nice but they don't have ICC code approvals yet, so an inspector might frown upon it. Also, I would not suggest installing a fitting of that type in a concealed location. I'm honestly not sure if they're listed for concealment in wall and floor spaces.
I think your best bet for making connections to the PEX is to spend $20 and rent a PEX tool. All rental places have them, and working with PEX is super-easy! I've found the connections to be highly reliable, and anybody can do it (as opposed to soldering, which a lot of people are not good at). If nothing else, run all your copper and make the connection to the existing PEX (after soldering everything) with a 1/2" sweat to 1/2" PEX fitting.
thekctermite is offline   Reply With Quote
Old 01-17-2009, 10:24 AM   #3
I didn't explain this very well. There is already copper in the floor. I want to connect pex. Do you have the same opinion?
Old 01-17-2009, 10:43 AM   #4
Yes, pex is much more simple and user friendly. You will still need to buy the adaptors which will have to be soldered to the existing copper lines(not hard at all) they sell slip in adaptors, that you could solder into a joint(ie; couplings, elbows) or they sell ones that slip over the pipe, which is probrably what you would use. And I would eliminate any dead ends in your copper.
zosoplumber is offline   Reply With Quote
More On This Topic
Hello! This is Ross on behalf of expertvillage.com. Cold solder connections. Sometimes you hear that word used in a way that means, "I do not know what is going on in the circuit." It is kind of like the general fault error message that you might see in... Read More »
Hello! This is Ross on behalf of expertvillage.com. In this clip, I am going to show you how to solder leads together. Each component has its own lead. So here I am going to use the helping hands. Then we will have them hold my wires here. That is all I... Read More »
Okay we have got all our pieces cut, they have been wrapped in foil, they have been fluxed, they are laid out in our pattern, I have kind of gotten them as tight as I can. You can see that there is some gaps between some of the piece and that is just a... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 6 of installing a ball valve. I am going to go ahead and show you a few tips for soldering. I am going to solder this ball valve on the ground primarily for the... Read More »
How to Tin a Soldering Iron
How to Tin a Soldering Iron by Expert Village
Hello! This is Ross on behalf of expertvillage.com. In this clip I am going to show you how to tin a soldering iron. This is a new soldering iron and the tip. If you replace the tip you want to tin also, tinning is when you take solder and flow it on the... Read More »
Want to tile bathroom - raise plumbing? schmolze Plumbing 2 11-13-2008 09:54 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 05:04 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 07:39 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 09:37 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 01:14 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
