Moving My Washer And Dryer - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2009, 11:39 AM   #1
moving my washer and dryer
hey everyone i've got another project i need some help with. would like to move my washer and dryer hookeups to the other side of the room. is this going to require removing the flooring or drywall in order to run the pipes. whats the level of difficulty associated with a project like this. thanx
coastalcomplete is offline   Reply With Quote
Old 03-03-2009, 05:32 PM   #2
yep and is there basement underneath? If not, this might be a major project.
II Weeks is offline   Reply With Quote
Old 03-03-2009, 09:08 PM   #3
living in florida so unfortunately no basement...i thought it would require removal of the flooring or at least a section of the drywall in order to extend the pipes...do the pipes have to be run underground...what would you charge for something like this
Old 03-03-2009, 09:23 PM   #4
you need to move supply lines for the washer, have a drain to hook up to and with the dryer, you need a power source, and a vent to the outside. Good time to sit back and see if you really want to move it from present location.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 03-03-2009, 10:45 PM   #5
How far are they moving?
Where are the drain pipes now? In the floor?
You need a certain amount of angle to the drain to make them work
And you also need a means of venting the new drain area
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Moving washer and dryer into Garage, perhaps some constucion needed? J187 Building & Construction 4 05-21-2008 12:53 PM
Moving washer/ dryer from 1st to 2nd floor sebastien1 Remodeling 33 11-08-2006 10:31 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
