Moving Laundry To The Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2011, 12:10 PM   #1
Question
Moving laundry to the basement
Hello
I need some help with my newest project. I want to move my laundry room from main floor to the basement (need to make the bathroom larger). The house used to be on a septic tank, but has been converted to city sewer. The main drain pipes go out the basement wall instead of the floor. The pipes are 3" and the center of the pipe is 57" off the unfinished basement floor. I will be building walls around this, but will not finish this room. My question is - how can I hook up the drain pipe? Will I need to build a platform to raise the washer? Any help is greatly appreciated!
needshelp2 is offline   Reply With Quote
Old 04-02-2011, 12:49 PM   #2
Learning by Doing
Leah Frances's Avatar
Just following the thread good luck. I'm looking at doing a similar project.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-02-2011, 04:16 PM   #3
Rewards Points: 1,512
The mouth of the washing machine drain riser has to be at least 18 inches above where its trap ties into the house drain line and (not relevant here) above the level where water would overflow out of the washer itself if the water got stuck on. It's a minimum of 2 inches in diameter so I think that makes the mouth 19 inches above the center of the drain pipe. So 57 plus 19 is 76 inches above the floor.
The existing washing machine drain hose must be able to reach it and fit down in loosely. No splicing on an extension hose.
A platform for the washing machine is possible.
If this is too high, you will have to install a sewage holding tank and pump.
Old 04-03-2011, 08:15 AM   #4
Owner
LateralConcepts's Avatar
I wouldn't suggest trying to elevate the washing machine. Use a pump system instead as AllanJ mentioned. Something like the Liberty 404 http://www.libertypumps.com/Products...?p=19&s=8&c=15
If you plan to eventually put additional fixtures, i.e. a toilet, etc. in the basement then you'll need a larger pump and basin installed under the slab. Something like this: http://www.libertypumps.com/Products...p=71&s=10&c=18
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 04-03-2011, 09:11 AM   #5
Thumbs up
Thank you so much for your responses. This gets me pointed in the right direction.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Basement laundry room secutanudu Electrical 9 04-23-2010 03:23 PM
Moving washer/dryer from basement to 2nd floor DIY newbie Appliances 3 02-14-2010 07:38 AM
Help moving ductwork in order to finish my basement Rhat HVAC 7 06-15-2009 08:57 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
