Moving Kitchen Sink To Adjacent Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2012, 10:46 AM   #1
Moving Kitchen Sink to Adjacent Wall
My kitchen layout currently looks similar to this diagram:
Behind the kitchen sink (in the bathroom) is the main vent stack for the house.
I would like to move the kitchen sink to the adjacent wall where the stove is but I am not sure how I would tie back into the vent or drain.
Is this even worth the hassle?
farang is offline   Reply With Quote
Old 09-08-2012, 10:51 AM   #2
Originally Posted by farang View Post
...I would like to move the kitchen sink to the adjacent wall where the stove is but I am not sure how I would tie back into the vent or drain...
If you've got a crawl space & attic, it's be easy. If you're on a slab & vaulted ceilings, not so much.
VIPlumber is offline   Reply With Quote
Old 09-08-2012, 10:54 AM   #3
I am on a slab. I do have an attic
Old 09-08-2012, 11:30 AM   #4
Do you know if the "stove wall" is an exterior or load bearing wall?
allthumbsdiy is offline   Reply With Quote
Old 09-08-2012, 01:31 PM   #5
The stove wall is an exterior wall
Old 09-10-2012, 09:01 AM   #6
Should I make a new vent above the new kitchen sink?
Old 09-12-2012, 08:22 AM   #7
I came here for advice, anyone got any?
Old 09-12-2012, 07:34 PM   #8
DIY staff
Rewards Points: 7,174
If you choose to move that you either have a lot of holes to drill through the exterior studs--or some concrete to break up.
I like to break open a floor--so my first impulse would be to open the floor for the sink drain---the vent will be easy enough to get up into the attic and tie in to the existing vent.
Old 09-12-2012, 07:59 PM   #9
by any chance, is there a dishwasher on that "stove wall"?
if yes, you can probably swap it with a kitchen sink.
otherwise, i don't think it is worth the hassle.
Venting inadequate with AAV Kitchen sink DownStream Plumbing 1 07-31-2012 11:57 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Moving kitchen sink teachtech Plumbing 4 08-08-2010 10:13 PM
lowering iron sink drain in kitchen wall leeb Plumbing 2 07-09-2010 09:11 AM
Plumbing Kitchen Sink on Outside wall in Cold Weather Climate (MN) tpthaler Plumbing 4 04-15-2010 07:36 AM
