Old 08-08-2010, 08:06 PM   #1
Moving kitchen sink
I have a 2.5 inch vent that goes from the basement sink up to first floor sink than to roof. I want to move the kitchen sink about a foot more away from vent stack (about 4'awaY). The easiest way I see is with an s-trap going through the floor from the sink and tie into the vent/drainpipe underneath the floor joist in the basement. Is it okay to tie the sink into the drain/vent from the basement rather then through the wall? Thank you in advance.
teachtech is offline   Reply With Quote
Old 08-08-2010, 08:48 PM   #2
Owner
LateralConcepts's Avatar
Moving kitchen sink
No. An s-trap isn't legal. Run it through the wall. You're only going 4' should be pretty easy. Actually easier than you make it sound.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 08-08-2010, 09:16 PM   #3
Moving kitchen sink
If I cannot use an s-trap I would have to move the vent stack slightly. I would have to run it through an exterior wall and then it would have to run through at an angle through the bottom half of the sink cabinet. I cannot run it through the sill plate going into the basement since there is a double joist below. Is this something that is usually done?
Old 08-08-2010, 09:28 PM   #4
Owner
Moving kitchen sink
Can you post a picture. I'm kinda visual.
Lateral
(208) 818-8241
Old 08-08-2010, 11:13 PM   #5
Moving kitchen sink
Vent pipe must be moved to exterior wall (by the new sheathing)but it cannot go through the bottom plate due to double joist below that are in the way. Can it go down the wall and then slightly angled through cabinet, down to basement?
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 10:16 PM
Help: Kitchen sink drain is clogged with grease cips Plumbing 4 08-10-2009 11:11 AM
Kitchen sink basket strainer hkm2 Plumbing 1 08-06-2009 07:44 AM
How difficult to remove a kitchen sink? KE2KB Plumbing 6 11-14-2008 04:28 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
