Moving/Installing New Mixing Valve... Issues With Framing - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2010, 02:10 PM   #1
Question
Moving/Installing new mixing valve... issues with framing
Hi all,
I'm in the middle of a bathroom remodel and am at the point where I'm replacing the mixing valve, etc. for the tub/shower. I'm installing a Symmons Allura valve, with a 2 3/8" +- 1/2" rough.
After doing all my figuring for the depth of the new wall (tile, mastic, 1/2" drywall) I've located the centerline depth for the supply pipes coming up from the floor. I've also figured out where the drain will be for the new tub... and of course the new drain is 1 1/2" off the center of the existing drain. This means that for the new drain, valve, and shower to line up... I have to move the mixing valve over 1 1/2". You can see the new mixing valve center line in the pics, just above and to the left of the existing valve (to the right of the stud).
The problem with this is that if I do that... taking into account the depth of the mixing valve/supply lines... one of my supply lines would be smack in the middle of the adjacent stud. The other side is the finished wall of a stairwell... so moving the stud involves new drywall, paint, and ladders to install it all. Not ideal.
So... I'm looking for ideas! How do I get this mixing valve in, centered with the drains on the tub (so it doesn't look weird being off-center) without demolishing more than I need to? Thanks for the help!
~Allan
Moving/Installing new mixing valve... issues with framing-img_2746-1.jpg   Moving/Installing new mixing valve... issues with framing-img_2747-1.jpg   Moving/Installing new mixing valve... issues with framing-img_2750-1.jpg
rodney23 is offline   Reply With Quote
Old 12-12-2010, 02:27 PM   #2
Handyman
Rewards Points: 512
You can always install a sister stud to the left of the existing one, then notch out the existing stud to make room for the plumbing.
canadaclub is offline   Reply With Quote
Old 12-12-2010, 02:48 PM   #3
DIY staff
Rewards Points: 7,174
Exactly what Canadian club said----Notch the stud--add one or two new ones--no need to disturb the drywall on the backside of the wall----
Old 12-12-2010, 04:05 PM   #4
The problem I see with notching would be I have to notch all the way to the floor. Not just at the point of the mixing valve, in order to accommodate the supply pipe coming up from the floor. The depth of the center-line of the supply pipes is basically the edge of the original wall stud (I've had to extend the studs to get the space from 61+ down to 60"... the length of the tub, 60x30... you can see the extensions on the other 2 studs and the outside corner). So, I'm relying on a little bit of flex in the pipe to shift the 1/2" inside the stud space I need to get the correct depth from the finish wall.
The only other thought I had was to extend the studs on the left by attaching a 1-1/2 by 1-1/2 piece of wood, thereby pushing the entire tub to the right 1-1/2". This would keep me from having to shift the plumbing over and I could just replace the mixing valve and pretty much leave the supply and shower pipes as-is and just put in the new valve. The issue with this approach would be I'm starting to encroach on my toilet space and I'd have to add in some sister studs on the adjacent walls to re-create the inside corners needed to hang the drywall.
Admittedly... that second option sounds like more effort with little gain now that I've written it out. Guess I'll probably go with the notching and hope for the best.
Hmmm... trying to remember why I didn't hire someone for this! :-)
Old 12-12-2010, 04:12 PM   #5
the supply pipes do not need to extend straight up from the floor to the new valve. leave them where they are, notch for the new valve, then use a couple 45's or 90's to get them where they need to be. same goes for the shower riser
the_man is offline   Reply With Quote
Old 12-12-2010, 04:17 PM   #6
Handyman
Rewards Points: 512
Yep, and use 45's..less restriction
Old 12-12-2010, 04:32 PM   #7
How about extending the piece of pipe coming out of the valve? Then you just have to drill a hole in the stud for the pipe to stick through, and maybe another hole to get back to the correct side? Does that make sense?
broox is offline   Reply With Quote
Tags
framing , mixing , plumbing , stud , valve
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 10 11-08-2013 01:25 PM
re-soldering a valve joint rtoni Plumbing 9 11-05-2010 11:04 AM
dual shower head mixing valve Clem Plumbing 0 10-20-2010 07:34 PM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 12:02 PM
Odd Framing Issues woodlayson Building & Construction 1 03-08-2008 11:13 PM
