Moving A Hose Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2012, 01:04 PM   #1
Moving a hose faucet
Hey everyone. I am renting a house and want to "temporarily" move an outdoor faucet. I live in Miami so I don't have to worry about the line freezing.
I wanted to some how attach the faucet in the back of the house to pvc and run it to the other side of the house and have my new faucet over there. I don't know what sizes of pipe to use and I also don't know if this is recommended or not. I've already had a hose break from the constant pressure after a few months and I wanted to make sure it would last for at least 3 years.
bbzoe is offline   Reply With Quote
Old 03-24-2012, 01:25 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
˝ pvc will be fine, if exposed to the sun you’ll need to paint it, ultraviolet light kills pvc, just put a shut off at the beginning of that new line run.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-24-2012, 02:35 PM   #3
is there anything flexible that can do this? I've been seeing some stuff about "funny pipe."
Old 03-24-2012, 02:40 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 676
You can run it in pex, but it too is susceptible to UV. Use adapter fittings for material transitions. Run 3/4 or 1/2" line secure pex @ 32" intervals. Plastic pie @ 6ft intervals.
Old 03-24-2012, 02:42 PM   #5
only reason I would want it flexible is to run it behind the 4x4's along a fence and the fence is very crooked.
Old 03-24-2012, 02:55 PM   #6
Plumber
Rewards Points: 676
Then I would suggest pvc or poly pipe- similar to funny pipe but better
Frozen outside faucet leaks -> Hose left attached k6trouble Plumbing 13 07-01-2013 11:29 AM
My hose does not fit the outdoor faucet, see picture inside. homenewbie Plumbing 7 07-24-2011 08:14 PM
running extension from outside garden hose faucet denemante Plumbing 6 05-27-2011 12:18 PM
relocating an outdoor hose faucet beerdog Plumbing 3 08-11-2010 03:34 PM
