Moving Expansion Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2010, 03:18 PM   #1
New House Newbie
Rewards Points: 95
I am going to install a whole house humidifier system and the space I need on the side of my furnace duct is obstructed by my expansion tank of my water heater. Can I just move this; by heatiing up the solder and swing it towards the wall more? I only need a couple inches so a whole relocation is not necessary. What do I need to do to drain the tank (if necessary)? I tried just grabbing it and trying to turn in with the screw in type fittings, but it would not budge.
Any of hints would be appreciated.
Moving Expansion Tank-dsc00678.jpg   Moving Expansion Tank-dsc00679.jpg   Moving Expansion Tank-dsc00680.jpg
C_J_GO is offline   Reply With Quote
Old 01-09-2010, 06:56 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,... Basically, the "T" fitting you want to turn has to be drained, Dry, then heated to turn...
You can't solder pipes with water in them,...
Bondo is online now   Reply With Quote
Installing a new boiler expansion tank CoachDad HVAC 0 01-06-2010 02:12 PM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 05:49 PM
Expansion tank location?? rcassidy HVAC 4 10-06-2009 10:01 AM
Installing new expansion tank ted schumm HVAC 2 07-19-2009 10:49 PM
