Moving Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-07-2012, 11:49 PM   #1
Moving drain pipe
My wife and I will be finishing our basement in the near future. I am currently doing the floor layout and have an issue.
The basement has the plumbing for the tub and toilet and sink drainage already. I do not like the placement and was wondering how much it would cost roughly to have it moved. The toilet and sink would move. The tub is fine.
They would move roughly 5-8 feet.
I have 6+ inches of cement and the job would be snaking the current pipe to see how it's ran? Then just drilling into the concrete and rerunning the plumbing...? Right? After that is done I could just use some bondage and cement mix and pour it back in?..
Talgonadia is offline   Reply With Quote
Old 08-08-2012, 12:17 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
as for costs, you need to get quotes from local plumbers. If you want to do it yourself, post some pictures of the existing work. There are several knowledgeable people here to offer guidance.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
closet flange ....over the drain pipe or inside the drain pipe moegumble Plumbing 2 08-18-2009 07:09 AM
Installing Wye to Existing Drain Pipe alladin15 Plumbing 1 08-17-2009 10:23 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
