#1 |
moving a drain
I have to move an existing drain for a shower. I have crawl space access to the pipe. I only need to move it about 6 inches at the most - I was planning on cutting the existing pipe (ABS) that shoots straight down into the U-bend, and applying a couple of 45 degree couplers - one to get under the spot I need the drain, and one to straighten the pipe back out. Then to glue them in place - does this sound OK?
#2 |
Master General ReEngineer
moving a drain
Ayuh,.. That should work Just Fine...
#3 |
moving a drain
Sounds good make sure you use the same kind of pipe ABS with the proper glue.
| Display Modes | |
| Moving Toilet drain 10" | lovinyale | Plumbing | 5 | 11-16-2008 01:05 AM |
| Condensor drain | Captflx | HVAC | 6 | 08-17-2008 11:19 AM |
| Wierd Floor Drain "Backup" | rawkintrevo | Plumbing | 9 | 06-04-2008 08:10 PM |
| The Bioswale, french drain, deck, drainage dilemma (long) | seabright_sc | Building & Construction | 2 | 01-05-2008 04:37 PM |
