Moving A Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2013, 11:30 AM   #16
Rewards Points: 34
Sorry if I wasn't clear. The pipe is 2 inches (the part that is glued). The adapter is 1 1/2 inches which will match the PVC tubing you use to create the drain.
Dan
djlandkpl is offline   Reply With Quote
Old 04-11-2013, 11:49 AM   #17
Rewards Points: 31
Yea I think I get it. The adapter actually slips INTO the drainpipe and not over it correct?
warrior58d is offline   Reply With Quote
Old 04-11-2013, 11:57 AM   #18
Rewards Points: 31
Mine looks like this
Old 04-11-2013, 12:12 PM   #19
Rewards Points: 34
That's the male version. That fitting would go into the hub of another fitting or coupling.
You need a female fitting so it fits over the pipe sticking out of the wall. The female fitting has the hub on it.
Dan
Old 04-11-2013, 05:35 PM   #20
Rewards Points: 1,956
Use a 1 1/2 female ABS trap adaptor like a real professional plumber would do.
http://www.lowes.com/pd_75356-137-CL...ductId=3436934
washing machine drain issues lost_punk Plumbing 2 06-19-2012 10:18 AM
moving shower drain - concrete basement williamwiens Plumbing 9 01-13-2011 03:22 PM
Tying into 50's style clay drain tile perimiter system/exposed Pit / Wall membrane alecmcmahon Plumbing 6 12-29-2010 07:23 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
