Just when I thought I had a productive weekend towards completeing my kitchen remodel I hit a problem, after hooking up my garbage disposal, then the elbow that comes with it, then the Tee for the 2nd bowl, and then the Pee trap, I sit below my wall DWV outlet. My house has cast iron DWV pipes, and was wondering what I could use to lower the outlet i.e. what type of tools, to cut, and if I could install PVC or if I have to keep using cat iron. My walls a completely finished on the kitchen side, but I could removed the sheetrock from the garage side and do my thing.
Thanks for the feedback. I ended up installing a Pee trap on each run and then doing a Yee at the wall inlet,avoiding the Tee on the disposal side kept me at the same level as the wall inlet.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
