-   -   Moving bathroom rough-in (http://www.diychatroom.com/f7/moving-bathroom-rough-165620/)
jonhayden 12-04-2012 10:04 PM
Hi,
I'm going to finish my basement in Colorado and need to move the bathroom rough-in. To start with, the sump pump in the original builder plan doesn't even exist in the builder plans location so that space is free to use. However, because of where they put the water heater, the hallway would be too narrow to use with the existing rough-in. So I'm proposing the following...see image. My question is, will code allow me to do this? Are angles okay? extending the distance okay? pipe size okay? Also, there is no venting anywhere in the rough-in. I've looked up down, sideways, and there is nothing. I asked the builder and he said his plumber said it's okay to use an Air Admittance Valve so I'm hoping that's okay too.
http://i1292.photobucket.com/albums/...om_remodel.jpg
Now, figuring out how to bust up the concrete is another topic all together :)
Thanks,
Jon
jonhayden 12-04-2012 10:15 PM
Not sure if this helps, but my town uses:
The International Plumbing Code, 2006 Edition
tylernt 12-05-2012 11:35 AM
Assuming your local jurisdiction has no local amendments, from what I can tell AAVs do appear to be permitted under the 2006 IPC if there is at least one "real" vent through the roof somewhere else in the house.
However, AAVs have to be accessible for servicing and be able to "breathe" air freely, so you can't bury it in a wall. Under the sink would be the logical place for it. The AAV has to be within a certain distance of the traps it serves, so you may need to run the trap arms from the shower and toilet straight to the sink for the AAV, before turning to enter the main drain line. So instead of that branching Y configuration in your pic, you may need more of a T layout with the sink in the middle. I believe you'll also need a 3" AAV to match the largest drain in the system.
jonhayden 12-05-2012 02:16 PM
Thanks for your reply tylernt! My home has 2 vents that I can see so I should be okay there. And I was definitely planning on making the AAV accessible. I was even thinking about purchasing something like this recess box:
http://www.ipscorp.com/images/news/A...ssBox_news.jpg
When you mention a T layout, do you mean something like this?
http://i1292.photobucket.com/albums/...m_remodel2.jpg
Thanks again,
Jon
tylernt 12-05-2012 02:26 PM
Say, that's nice, gives you more flexibility on where to put it.
Where will you put the AAV?
jonhayden 12-05-2012 02:29 PM
I was thinking in the wall that's between the shower and sink.
Beepster 12-05-2012 02:38 PM
You say your home has two vents... are any of these accessible from the basement? I believe, if at all possible, you should try and vent your basement bathroom out through the roof. The AAV is just a last resort when it is not possible to properly vent.
B
jonhayden 12-05-2012 02:48 PM
B
They're on the complete opposite side of the basement, which is why I was going the AAV route. Thanks
tylernt 12-05-2012 03:07 PM
Based on this thread:
http://www.diychatroom.com/f7/distan...t-vent-146308/
it looks like that AAV location and your T layout will work. Of course use sweep fittings, not 90 corners.
Shower is 2 DFU, lav is 1 DFU, 2" pipe supports 6 DFU on a horizontal branch, so you're good size-wise.
jonhayden 12-06-2012 06:05 PM
Just to confirm. Does this look right? And I'm curious about the type of pipe connection to use between the 3" and 2" pipes. By sweep fitting, do you mean a Y? And is a T okay where the AAV pipe meets the sink/shower pipe? Thanks
http://i1292.photobucket.com/albums/...n/bathroom.jpg
tylernt 12-06-2012 07:08 PM
1 Attachment(s)
Yeah, the 45 Y fittings are the least likely to clog.
As for the 2" meeting the 3", you may be able to find a 3x3x2 Y like the one shown below, but it's just as effective to come off a 3x3x3 Y with a 3-2 reducer coupling, so don't drive all over town looking for the 3x3x2.
As far as I know, vents can use hard 90 tees though.
jonhayden 12-06-2012 07:27 PM
Thanks for your help. Much appreciated.
Jon
jonhayden 12-06-2012 08:00 PM
Final solution. Need to see if a cleanout is required, but I think this works good for me.
http://i1292.photobucket.com/albums/...odel_views.jpg
tylernt 12-06-2012 08:20 PM
I found this that mentions clean outs:
www.finehomebuilding.com/PDF/Free/021126070.pdf
