Moving Bathroom. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2012, 10:25 PM   #1
Moving bathroom.
Hi all, my first time posting so I do apologize ahead of time if I mess up and make things more complicated then they should be. lol
I plan on moving my bathroom from one side of my house to the other side. I do have a couple questions.
- 3" abs running at a 1/4 inch per foot drop(in crawl space) from new toilet,sink,shower to existing stack (estimated distance will be approx. 35 feet). Is this possible ?
- if this is possible I have a 3inch vent at the stack end now I would leave that there and have all fixtures in new bathroom tied into a 2" that I have fed up through the roof.
kevin705 is offline   Reply With Quote
Old 02-18-2012, 10:52 PM   #2
Rewards Points: 636
to me the 35 feet is not a problem as long as you have the 9 inches you have to rise to get to new location make sure you use wye's on the horizontal drain pipe and the vent should be a increase to a 3 inch 1 foot under deck then through roof at least 1 foot as long as there or no windows from a second story at least where i live
jaydevries is offline   Reply With Quote
Old 02-18-2012, 10:54 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 818
3" pipe is graded at 1/4" per ft. Do you have the elevation to do that?
A typical bathroom can vent with a 2" vent
Old 02-18-2012, 11:04 PM   #4
Rewards Points: 636
e plumber i agree with the 2 " vent is more than efficient since a bathroom group is 6 dfu's and main to bath is a 3 " but i was taught it is code to have a 3 penetration through roof with a minimum of 12 " below roof deck do you know if that is code
Old 02-18-2012, 11:13 PM   #5
Plumber
Rewards Points: 818
I was taught that this is applicable in frost zones only. However, the cross sectional area of all vents must equal the building drain size, he indicates an existing 3" vent will remain.
The only code I have worked under is the UPC so I can't speak for all...
Old 02-18-2012, 11:15 PM   #6
Rewards Points: 636
thanks
Old 02-18-2012, 11:44 PM   #7
All your advice is greatly apprecciated.
Not sure what you mean under deck to go 3" with the vent. But as soon as this 2" vent enters the attic I increased to 3 to go up through the roof. And there is also a 3" vent from the main stack in the crawlspace still.
Under the floor the 2" vent is tied into the 3" drain line.
And would simple galvanized strapping support this throughout the crawlspace until I hit the main stack ?
Old 02-19-2012, 12:43 AM   #8
Plumber
Rewards Points: 818
"Deck" is referring to roof deck.
ABS pipe needs to be supported every 4ft. Strapping is fine but you should try to eliminate vertical and lateral movement with a stiffener between the pipe and the floor joist
Old 02-19-2012, 01:46 PM   #9
Rewards Points: 636
for pipe hanging ask for j hooks they are easy to use
Moving a bathroom sink lisastewart Kitchen & Bath Remodeling 1 01-18-2012 10:51 AM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 10:14 PM
Help with bathroom elvis2010 Interior Decorating 9 02-01-2010 08:41 PM
Major Bathroom Renovation, planning advise LukeAU Kitchen & Bath Remodeling 1 12-24-2009 06:13 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
