Old 09-12-2008, 12:09 PM   #1
moving 2nd story toilet
I want to move a toilet over about 8 inches in a second story bathroom so I can make the shower bigger. I'm just curious what I would be getting into, is it worth it?? How much of a pain is it to move the existing drain pipe or can I put an adaptor or extension onto the already exisisting one? The drain pipe now runs N/S, I'm moving the toilet East(if that helps) tearing the plywood up isn't the problem, the whole bathroom is getting torn up anyways. Thanks.
tool is offline   Reply With Quote
Old 09-12-2008, 12:35 PM   #2
The main problem I see with this is if you have a floor joist in the area where the pipe would need to be. If could be done using two 45 degree elbows, but in such a short distance (most toilets are 12" from the wall) , it may be advisable to cut out the existing tee that goes into the main drain and installing a new one with the proper angle.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-12-2008, 02:39 PM   #3
That could work, I don't know where the tee comes in at in relation to the toilet. Just wondering how much floor I would have to rip up to get to it. But yeah there is a joist there, I would have to go under and around it. The bathroom sits pretty much right above the sewage drain. Thanks for your input.
Old 09-12-2008, 04:18 PM   #4
47_47's Avatar
You should also have a 15" minimum clearance from the center line of the toilet to both sides (wall, vanity, shower...)
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 02:22 PM
Moving Toilet cibula11 Plumbing 5 02-19-2007 09:47 PM
Moving toilet kevnew Plumbing 1 03-11-2006 12:52 AM
moving toilet farrington135 Plumbing 5 11-19-2005 05:29 PM
